Class 4 (4th Engineer) MEKG 📅 Jan 2025
(a) Sketch a line diagram showing a typical 'Inert Gas System' used for inerting the cargo tanks of oil tankers, labelling the component-parts. (6)
(b) Describe the system (8)
(c) State what oxygen content you would expect in the flue gases if good combustion is achieved. (2)
### (a) Line Diagram of a Typical Inert Gas System
A line diagram must be sketched showing the flow of inert gas from the boiler uptake to the individual cargo tanks. The following components, as described in detail below, must be clearly labelled:
1. **Boiler Uptake Funnel Valve** (Uptake from Main/Aux Boiler)
2. **Inert Gas Scrubber Tower** (showing sea water inlet/outlet, venturi, spray nozzles, demister)
