Class 4 (4th Engineer) MEKM 📅 Aug 2023
(a) Sketch a main engine jacket water cooling system (8)
(b) State why chemical treatment of such systems is necessary (4)
(c) What tests are carried out to ascertain the level of the concentration of the chemicals in the jacket cooling water system? (4)
### (a) Sketch a Main Engine Jacket Water Cooling System
The main engine jacket water cooling system is a critical auxiliary system designed to maintain the cylinder liners, cylinder heads, and turbocharger casings within their optimal operating temperature range. This is achieved by circulating a controlled flow of chemically treated fresh water, referred to as LT (Low Temperature) Central Cooling Water, through the engine's water passages. The system ensures efficient heat transfer from the engine components to the cooling water, which then transfers this heat to the main sea water cooling system via a central cooler.
**Key Components and Flow Path:**
1. **Main Engine (Cylinder Jackets and Heads):** Heat from combustion and friction is transferred to the LT Central Cooling Water circulating through the jackets surrounding the cylinder liners and the passages within the cylinder heads.
