Class 4 (4th Engineer) MEKM 📅 Jan 2024
(a) Sketch a main engine jacket water cooling system (8)
(b) State why chemical treatment of such systems is necessary (4)
(c) What tests are carried out to ascertain the level of the concentration of the chemicals in the jacket cooling water system? (4)
### (a) Sketch a main engine jacket water cooling system
The main engine jacket water cooling system is a closed-loop, freshwater-based system designed to maintain the main engine components (cylinder liners, cylinder heads, fuel injection valves, and sometimes turbocharger casings) within their optimal operating temperature range. This is crucial for efficient combustion, preventing thermal stresses, and ensuring the longevity of engine parts. The system typically utilizes LT (Low Temperature) Central Cooling Water as the primary cooling medium in the heat exchanger.
**Components and Operational Description:**
1. **Main Engine Jackets:** The primary heat load originates from the engine cylinder jackets, cylinder heads, and fuel injection valves, where the heat of combustion is transferred to the jacket water.
