(a) Sketch a main engine jacket water cooling system (8)
(b) State why chemical treatment of such systems is necessary (4)
(c) What tests are carried out to ascertain the level of the concentration of the chemicals in the jacket cooling water system? (4)
The main engine jacket water cooling system is a critical closed-loop system designed to maintain the engine's cylinder liners, cylinder heads, and other vital components within an optimal operating temperature range. This ensures efficient combustion, minimizes thermal stress, and prevents the formation of harmful deposits.
### (a) Sketch a main engine jacket water cooling system
**Concept:**
The system circulates treated fresh water (often referred to as High Temperature (HT) cooling water) through passages in the engine's components, absorbing excess heat generated during combustion. This heated water is then cooled in a heat exchanger, typically by Low Temperature (LT) Central Cooling Water, before being recirculated to the engine. The closed-loop nature prevents contamination and allows for precise chemical treatment.
