Class 4 (4th Engineer) SC&S 📅 Aug 2024
(a) Sketch a semi balanced rudder of your choice showing: (10)
(i) A detail of the hinges or pintles about which rudder turns.
(i) Details of the rudder carrier bearing, which supports the weight of the rudderstock and rudder.
(b) State advantages of semi balanced rudder over an unbalanced rudder. (6)
### (a) Description of a Semi-Balanced Rudder for Sketching
A semi-balanced rudder is designed to reduce the torque required to turn it, thereby allowing for smaller and more efficient steering gear. This is achieved by placing a portion of the rudder's surface area, typically 20-25%, forward of the turning axis (centerline of the rudder stock). When the rudder is turned, the hydrodynamic pressure acting on this forward 'balance area' creates a turning moment that counteracts the moment from the pressure on the aft main blade area.
#### (i) Details of Hinges or Pintles
The pintles and gudgeons form the hinge points for the rudder blade, providing radial support and allowing it to pivot smoothly. For a typical semi-balanced rudder on a vessel with a stern frame or skeg:
