Class 4 (4th Engineer) SSEP 📅 Jan 2024
(a) Sketch a simple line diagram showing a shipboard oil-water separator in series with a coalescing second stage (10)
(b) Describe the arrangement and operation of the separator sketched in (a) (10)
### (b) Arrangement and Operation of a Two-Stage Oily Water Separator
The primary purpose of a shipboard Oil Water Separator (OWS) is to process oily bilge water, separating the oil from the water to an extent that the effluent water can be legally discharged overboard in compliance with MARPOL Annex I regulations. The current international standard for discharge within Special Areas and for all ships built after 2005 is a maximum oil content of 15 parts per million (ppm).
The system described operates on a two-stage principle:
