Class 4 (4th Engineer) SSEP 📅 Aug 2023
(a) Sketch a simple line diagram showing a shipboard oil-water separator in series with a coalescing second stage.
(b) Describe the arrangement and operation of the separator sketched in (a).
### (a) Sketch
A simple line diagram is required, showing the key components and flow paths as described below. The sketch should clearly label:
1. Oily Bilge Water Inlet
2. Pump
