Class 4 (4th Engineer) MEKG 📅 Mar 2025
(a) Sketch an auxiliary boiler 'blow down' valve. Explain how it differs from its shipside counterpart. (10)
(b) Describe the sequence of 'blow down' procedure. (6)
### (a) Sketch an auxiliary boiler 'blow down' valve. Explain how it differs from its shipside counterpart.
#### Concept and Purpose
Blowdown valves are critical components on any boiler system, specifically designed for the periodic discharge of a small quantity of concentrated boiler water from the lowest parts of the boiler (e.g., mud drum or bottom headers). This process, known as 'bottom blowdown' or 'continuous blowdown' (though the question implies intermittent bottom blowdown), is essential to remove suspended solids, sludge, and reduce the concentration of dissolved solids (TDS) and alkalinity, thereby preventing scale formation, foaming, and corrosion within the boiler. The design of these valves is specialized due to the high-pressure, high-temperature, and erosive nature of the medium they handle.
#### Construction of an Auxiliary Boiler Blowdown Valve
