Class 4 (4th Engineer) MEKG 📅 May 2024
(a) Sketch an auxiliary boiler 'blow down' valve. Explain how it differs from its shipside counterpart (10)
(b) Describe the sequence of "blow down' procedure (6)
### (a) Auxiliary Boiler Blow Down Valve vs. Shipside Counterpart
#### Sketch and Construction of a Boiler Blowdown Valve
A typical auxiliary boiler blowdown valve is a **Parallel Slide Valve**. Its primary function is to handle the rapid discharge of high-pressure, high-temperature water containing suspended and dissolved solids (sludge) from the lowest point of the boiler.
**Key Components:**
