Class 4 (4th Engineer) SSEP 📅 Oct 2022
(a) Sketch and describe a 50 Ltrs Mechanical foam Fire Extinguisher, giving details with resprct to (12)
(i) Type of gs used as explants
(ii) Throw reach
(iii) Working and rest pressure
(b) Explain the procedure for re-charging the same after use (8)
### (a) 50 Litre Mechanical Foam Fire Extinguisher
A 50-litre mechanical foam fire extinguisher is a mobile, trolley-mounted unit primarily designed for tackling large Class B fires (flammable liquids like oil, petrol, paints) and is also effective on Class A fires (combustible solids like wood, paper, cloth). Its large capacity makes it suitable for machinery spaces, flight decks, and boiler rooms.
#### Construction
1. **Main Cylinder:** A welded steel cylinder with a capacity of 50 litres. The interior is lined with a polymer or other anti-corrosive coating to prevent reaction with the foam solution. The exterior is painted fire red with a distinguishing colour band indicating foam (cream coloured).
