Class 4 (4th Engineer) MEKG 📅 Jul 2023
(a) Sketch and describe a composite boiler and explain its working principle. (12)
(b) What do you understand by the term 'Heat Recovery'? Briefly explain as to how it contributes in increasing plant efficiency? (4)
### (a) Composite Boiler: Sketch, Description, and Working Principle (12 Marks)
A composite boiler is a type of marine boiler designed to generate steam using two independent heat sources within a single shell: the main engine's exhaust gas and a dedicated oil-fired burner. This dual-source capability provides operational flexibility, allowing for steam generation both at sea and in port.
#### Construction and Design
A typical vertical-type composite boiler consists of the following key components:
