Class 4 (4th Engineer) SSEP 📅 Mar 2025
(a) Sketch and describe a non-portable 136 liter foam fire engine. (8)
(b) Briefly explain how to operate the foam engine. (3)
(c) State the two constituents used, which enable stable foam to be produced. (3)
(d) State for what approximate length of time, the engine should generate foam (3)
(e) Where on board ship would you expect such an extinguisher to be located. (3)
### (a) Sketch and Description of a 136 Litre Foam Fire Engine
**Principle of Operation:**
The 136-litre chemical foam extinguisher operates on the principle of generating foam through a chemical reaction between an acidic solution and an alkaline solution. This reaction produces Carbon Dioxide (CO₂) gas, which is then trapped in a solution containing a foaming agent, creating a stable foam blanket. The foam extinguishes fire by smothering (cutting off oxygen), cooling, and suppressing the release of flammable vapours.
**Construction:**
