Class 4 (4th Engineer) MEKG 📅 Jun 2023
(a) Sketch and describe the 'drive mechanism' of a centrifuge? (10)
(b) State the components in the horizontal and vertical drives. (3)
(c) State the purpose of providing (3)
(i) clutch mechanism
(ii) worm & wormwheel
(iii) bowl assembly
The centrifuge drive mechanism is meticulously engineered to transmit power from a relatively low-speed electric motor to the high-speed rotating bowl assembly, while also providing essential speed reduction, torque multiplication, and shock absorption features.
**(a) Sketch and Describe the 'Drive Mechanism' of a Centrifuge**
The drive mechanism of a marine centrifugal separator typically comprises a robust electric motor, a friction clutch, a worm and worm wheel arrangement, and a vertical spindle supporting the bowl assembly. The entire mechanism is housed within a sturdy frame designed to withstand the operational stresses and vibrations.
* **Power Source**: The primary power input is generally provided by a three-phase alternating current (AC) electric motor, which typically operates at a standard industrial speed (e.g., 1450 RPM or 1750 RPM).
