Class 4 (4th Engineer) MEKG 📅 Dec 2023
(a) Sketch and describe the modern purification system using 'ALCAP' concept for purifying fuel with specific gravity about 0.991. (8)
(b) Explain how 'ALCAP' separater operates as clarifier & how is the water drained off? (5)
(c) What is 'paring disc'? How does it function? (3)
### (a) ALCAP Purification System for High-Density Fuel
The ALCAP (Alfa Laval Clarifier and Purifier) system is a modern solution for treating low-grade, high-density heavy fuel oils (HFO) with specific gravities up to 1.01 g/cm³ at 15°C. For fuels like the one specified (SG 0.991), the density difference between fuel and water is negligible, rendering traditional gravity disc-based purifiers ineffective. The ALCAP system overcomes this by operating as a clarifier with an intelligent, automated system for intermittent water removal.
**System Description and Key Components:**
1. **Centrifugal Separator Bowl:** A high-speed disc-stack type bowl that generates the high G-forces necessary for separation.
