Class 4 (4th Engineer) MEKM 📅 Dec 2023
(a) Sketch and describe the Starting air system of main engine. (8)
(b) What are the safety interlocks provided in compressed air Starting system of Main Engine? (8)
### (a) Sketch and Describe the Starting Air System of Main Engine
The starting air system is crucial for initiating the rotation of a large marine diesel engine, providing the necessary torque to overcome static friction and compression until the engine can fire and sustain combustion. It operates by admitting high-pressure compressed air into the engine cylinders in a timed sequence, pushing down the pistons to create rotational movement of the crankshaft.
#### Main Components and Their Functions:
* **Starting Air Compressors**: These are positive displacement compressors (typically reciprocating type) that draw in atmospheric air, compress it to a high pressure (commonly 20-30 bar), and discharge it into the starting air receivers. There are usually two main compressors and one emergency compressor, often driven by an internal combustion engine, to ensure redundancy and starting capability even in a 'dead ship' scenario.
