(a) Sketch and describe the Starting air system of main engine. (8)
(b) What are the safety interlocks provided in compressed air Starting system of Main Engine? (8)
### (a) Sketch and Describe the Starting Air System of Main Engine
**Concept:**
The starting air system in a main engine provides a sudden burst of high-pressure compressed air to the engine cylinders, initiating the rotational movement of the crankshaft. This initial impulse overcomes the static friction and compression resistance, bringing the engine up to a sufficient speed where fuel can be injected, ignited, and combustion can become self-sustaining. The system is designed to provide multiple successive starts without needing to replenish the air reservoirs immediately.
**Key Components and Construction:**
