Class 4 (4th Engineer) SSEP 📅 Feb 2024
(a) Sketch and explain the operation of the Quick Closing Valve? (10)
(b) What do you understand by the Emergency Shutdown System? Explain the operation in an emergency. (10)
### (a) Sketch and explain the operation of the Quick Closing Valve
A Quick Closing Valve (QCV) is a critical safety device designed to rapidly isolate flammable liquid tanks and piping systems in an emergency, such as a fire or significant leak. Its primary purpose is to prevent the uncontrolled flow of fuel oil, lubricating oil, or other flammable liquids that could exacerbate an incident.
#### Construction:
A QCV typically consists of the following key components:
