Class 4 (4th Engineer) MEKG 📅 Oct 2023
(a) Sketch in simple form a constant speed hele-shaw pump suitable for a hydraulic steering gear. (6)
(b) Describe the pump and its principle of operation. (5)
(c) What characteristics of the pump make it suitable for use in steering gear system? (5)
### (a) Sketch of a Hele-Shaw Pump
A simple cross-sectional sketch of a constant speed Hele-Shaw pump should clearly illustrate the following key components:
1. **Outer Casing:** The main body of the pump.
2. **Drive Shaft:** Connected to a constant speed electric motor, this shaft enters the casing and rotates the cylinder block.
