Class 4 (4th Engineer) MET 📅 Oct 2025
(a) Sketch, the circuit diagram of an instrument used for measuring electrical insulation resistance. (8)
(b) Describe the circuit diagram sketched in (a), explaining how it operates when measuring electrical insulation resistance. (8)
### (a) Sketch of Insulation Resistance Tester (Megger)
A circuit diagram for a moving-coil type insulation resistance tester is required. The sketch should clearly label the following components:
1. **Hand-Cranked DC Generator:** The high-voltage source.
2. **Permanent Magnet:** Provides the magnetic field for the meter movement.
