Class 4 (4th Engineer) SSEP 📅 Sep 2025
(a) State the areas where an emergency fire pump is commonly installed on a ship and explain the reasoning behind these locations. (6)
(b) What fuel arrangements are required for a diesel-driven emergency fire pump to ensure its independent operation? (4)
(c) What specific checks should be performed on the emergency fire pump during weekly drills? (6)
(d) Explain the precautions to be taken to protect the emergency fire pump system from freezing in sub-zero temperatures. (4)
### (a) Installation Areas and Reasoning for Emergency Fire Pump (6 Marks)
As per SOLAS Chapter II-2, Regulation 10, the emergency fire pump must be independently driven and located remotely from the main machinery space to ensure its availability during a fire in that primary high-risk area. The fundamental principle is to provide a completely separate and redundant means of firefighting.
**Common Installation Locations:**
* **Steering Gear Compartment:** This is a common location as it is situated in the aft part of the vessel, typically outside and separated by a fire-rated bulkhead from the main machinery space. Its location provides clear access and is generally well-protected.
