(a) State the necessary conditions required prior to the synchronizing of electrical alternators. (6)
(b) Describe the type of cumulative damage that may be caused when alternators are incorrectly Synchronized. (6)
(c) Explain how the damage referred to in (b) can be avoided/reduced. (4)
### (a) Necessary Conditions Required Prior to Synchronizing Electrical Alternators (6 Marks)
For successful and safe synchronization of an incoming electrical alternator to an active busbar (or parallel with other running alternators), the following four fundamental conditions must be met. Failure to satisfy any of these conditions can lead to severe damage and instability.
* **Voltage Magnitude Equality:**
* **Condition:** The Root Mean Square (RMS) voltage of the incoming alternator must be approximately equal to the RMS voltage of the busbar. Typically, the incoming voltage is adjusted to be within ±5% of the busbar voltage, ideally slightly higher (e.g., 1-2%) to ensure it immediately picks up reactive load upon connection.
