Class 4 (4th Engineer) MEKM 📅 Dec 2023
(a) State why double walled fuel pipes are employed for high pressure fuel lines. (6)
(b) Sketch and describe such a double walled pipe arrangement and show how high pressure pipe failure is indicated. (10)
### (a) Reasons for employing double-walled fuel pipes for high-pressure fuel lines
Double-walled fuel pipes, often referred to as 'shielded' or 'jacketed' piping, are mandated for high-pressure fuel oil lines primarily due to critical safety, environmental, and operational considerations. The primary objective is to prevent the escape of highly flammable fuel under pressure into the engine room, especially onto hot surfaces or into the atmosphere as a fine mist.
* **Fire Hazard Mitigation:**
* High-pressure fuel lines carry fuel at pressures that can exceed 1000 bar (for common rail systems) or several hundred bar (for traditional jerk pump systems). A rupture or leak in a single-walled pipe at such pressures would result in a fine, atomized spray or mist of fuel. This fuel mist, if it comes into contact with hot surfaces (e.g., exhaust manifolds, turbocharger casings, steam pipes) whose temperatures exceed the autoignition temperature of the fuel, can spontaneously ignite, leading to a catastrophic engine room fire. The double-walled design provides a secondary containment barrier, preventing this high-pressure spray from escaping.
