Class 4 (4th Engineer) MEKM 📅 Jan 2023
(a) State why jacketed fuel pipes are employed for protection of high pressure fuel delivery lines between the high pressure fuel pumps and fuel injectors. (4)
(b) Sketch and describe such a jacketed pipe arrangement and show how high pressure pipe failure is indicated. (12)
### (a) Purpose of Jacketed High-Pressure Fuel Pipes
Jacketed or sheathed high-pressure fuel pipes are a critical safety feature mandated by SOLAS (Chapter II-2, Regulation 4) for use on marine diesel engines with a power output greater than 375 kW. Their primary purpose is to **prevent engine room fires** by containing fuel leaks.
Key reasons for their employment are:
1. **Containment of High-Pressure Leaks**: The high-pressure fuel lines between the fuel pump and the injector operate at extremely high pressures (up to and over 2000 bar). A failure in this line (e.g., from fatigue, vibration, or improper fitting) would result in the fuel being released as a fine, highly atomized spray or aerosol.
