Class 4 (4th Engineer) SSEP 📅 Nov 2022
(a) State why oxygen deficiency may occur in certain spaces onboard ship. (6)
(b) Describe the precautions to be taken before entry to any recently opened enclosed space. (6)
(c) Why a SCBA bottle is checked before use, and what provision is there for warning regarding the bottle content? What checks are made on SCBA? (8)
### (a) Reasons for Oxygen Deficiency in Shipboard Spaces
An atmosphere is considered oxygen-deficient when the oxygen concentration falls below 20.9% by volume (safe working level as per regulations, with alarms often set at 19.5%). Oxygen deficiency can occur due to two primary mechanisms: **consumption** and **displacement**.
Based on the provided context and established maritime safety principles, the reasons are as follows:
1. **Oxidation (Corrosion):** The process of rusting is the chemical reaction of iron (steel) with oxygen. In enclosed, damp spaces like ballast tanks, chain lockers, and cofferdams, this process can consume a significant amount of oxygen from the trapped atmosphere over time, leading to a dangerously deficient environment.
