Class 4 (4th Engineer) MEKG 📅 Jul 2022
(a) The steering gears used onboard can be a variety of types; classify the various types with a simple chart. (8)
(b) Describe the Statutory Requirements for
(i) A main steering gear, and, (4)
(ii) an auxiliary steering gear as can be described for an electro-hydraulic steering gear, using a sketch, defining all important parts as fitted in the steering compartment. (4)
### (a) Classification of Steering Gear Systems
Steering gears can be classified based on their principle of operation and construction. The following chart illustrates the common types found on board merchant vessels:
### (b) Statutory Requirements for Steering Gears (as per SOLAS Ch II-1 Reg 29)
These requirements ensure the safe maneuverability of the vessel under all normal and emergency conditions.
