(a) There are three auxiliary engines having separate quick closing valves in the fuel supply line. How will you safely test these valves for each of the engines without causing a black-out? Discuss the process with the help of a diagram. (6)
(b) How will you reset the quick closing valves after the test is completed? (4)
(c) Explain the significance of flywheel marking on a four stroke engine. (6)
