Class 4 (4th Engineer) MEKM 📅 Jun 2024
(a) What are the advantages of a thin shell bearing? (4)
(b) What are the typical bearing failures? Discuss at least four bearing failures. (8)
(c) Why is periodic analysis of the lubricating oil important? (4)
### (a) Advantages of a Thin Shell Bearing
Thin shell bearings have largely superseded thick shell bearings in modern marine diesel engines due to several significant advantages, primarily related to their construction, performance, and maintainability. These advantages contribute to improved engine reliability and reduced operational costs:
* **Superior Heat Dissipation:**
* Thin shell bearings consist of a thin layer of bearing material (e.g., Babbitt, tri-metal, or lead-bronze) bonded to a rigid steel backing. This thinness, coupled with the high thermal conductivity of the steel back, allows for highly efficient transfer of heat generated by friction away from the bearing surface and into the bearing housing, which is typically cooled by LT Central Cooling Water or engine oil. This prevents localized overheating and maintains the oil film integrity.
