Class 4 (4th Engineer) MEKM 📅 Oct 2024
(a) What are the advantages of a thin shell bearing? (4)
(b) What are the typical bearing failures? Discuss at least four bearing failures. (8)
(c) Why is periodic analysis of the lubricating oil important? (4)
### (a) Advantages of a Thin Shell Bearing (4 Marks)
A thin shell bearing, often referred to as a precision insert bearing, consists of a thin layer of bearing material (such as white metal, aluminium alloy, or copper-lead alloy) bonded to a steel or bronze backing. This design offers several significant advantages over traditional thick-walled, cast-in-place bearings, particularly in modern high-speed and highly loaded machinery:
* **Superior Heat Dissipation:** The thinness of the bearing material, coupled with the high thermal conductivity of the steel or bronze backing, allows for very efficient transfer of heat away from the bearing surface to the housing. This helps maintain the lubricating oil's viscosity and prevents localized overheating, thereby reducing the risk of wiping or thermal degradation.
* **Improved Fatigue Strength:** The strong steel backing provides robust support for the relatively softer bearing material. This significantly increases the overall fatigue strength of the bearing, allowing it to withstand higher dynamic loads and cyclic stresses encountered in internal combustion engines and other demanding applications without developing cracks or spalling.
