Class 4 (4th Engineer) MEKG 📅 Jun 2024
(a) What are the different types of coupling bolts used in practice? Name at least 3. (3)
(b) Explain with the help of sketch, as to how a 'pilgrim' hydraulic bolt is fitted and removed? (8)
(c) How are fitted bolts installed on the coupling? (5)
### (a) Different Types of Coupling Bolts
The three primary types of bolts used for shafting flange couplings in marine practice are:
1. **Fitted Bolts (Parallel Shank Bolts):**
* These bolts have a straight, parallel shank that is precision-machined to be an interference fit in the corresponding reamed holes of the coupling flanges.
