Class 4 (4th Engineer) MEKG 📅 Nov 2024
(a) What are the different types of coupling bolts used in practice? Name at least 3. (3)
(b) Explain with the help of sketch, as to how a 'pilgrim' hydraulic bolt is fitted and removed? (8)
(c) How are fitted bolts installed on the coupling? (5)
### (a) Different Types of Coupling Bolts
Based on common marine practice and the provided information, three primary types of coupling bolts are used to connect shaft flanges:
1. **Fitted Bolt (Parallel Shank Bolt):**
* **Description:** This is a solid, parallel-shank bolt machined to a very precise diameter to be an interference or close-clearance fit in the reamed holes of the coupling flanges.
