Class 4 (4th Engineer) SC&S 📅 Jul 2024
(a) What are the different types of stern used in ship construction? (6)
(b) A ship consumes 360t of fuel, stores and water when moving from sea water of 1.025 t/m3 into fresh water of 1.000 t/m3 and on arrival it is found that the draught has remained constant. Calculate the displacement in sea water. (10)
### (a) Different Types of Sterns Used in Ship Construction
The stern of a ship is a critical structural element that significantly influences a vessel's hydrodynamics, stability, maneuverability, and cargo capacity. The design of the stern varies widely depending on the ship's intended purpose, operational speed, and the type of propulsion system employed. A well-designed stern optimizes water flow, reduces resistance, protects the propeller and rudder, and contributes to overall seaworthiness. The primary types of sterns include:
1. **Cruiser Stern (or Canoe Stern):**
* **Description:** This is the most common type of stern found on modern merchant vessels and passenger ships. It is characterized by its rounded, streamlined shape that slopes gently from the deck aft to the waterline, merging smoothly into the hull. The main deck typically extends well aft over the rudder and propeller arrangement.
