Class 4 (4th Engineer) SSEP 📅 Aug 2024
(a) What are the sulphur limits for fuel in use under MARPOL? (5)
(b) What happens if complant fuel cannot be obtained in the port of bunkering? (5)
(c) What if the sulphur analysis resulting from a commercial analysis does not match the bunker delivery note. (5)
(d) What are the timelines for installation of "in use" fuel sampling points on ships? Does it apply for existing ships? (5)
### (a) Sulphur Limits for Fuel in Use Under MARPOL
Under Regulation 14 of MARPOL Annex VI, the limits for sulphur content in fuel oil used on board ships are as follows:
1. **Global Sulphur Cap**: For ships operating outside designated Emission Control Areas (ECAs), the maximum sulphur content of fuel oil used on board is **0.50% m/m (mass by mass)**. This regulation came into effect on 1st January 2020.
2. **Emission Control Area (ECA) Sulphur Cap**: For ships operating inside an ECA established to limit SOx and particulate matter emissions, a more stringent limit applies. The maximum sulphur content of fuel oil used on board within these areas is **0.10% m/m (mass by mass)**.
