Class 4 (4th Engineer) MET 📅 Mar 2025
(a) What is the difference between a DC Generator and a DC motor? (6)
(b) A 4-pole, 32 conductor, lap-wound DC shunt generator with terminal voltage of 200 V delivering 12A to the load has Ra = 2 and field circuit resistance of 200Ω. It is driven at 1000 RPM. Calculate
(i) The flux per pole in the machine.
(ii) If the machine has to be run as motor with the same terminal voltage and drawing 5A from mains, maintaining the same magnetic field, find the speed of the machine. (10)
### (a) Difference Between a DC Generator and a DC Motor
A DC generator and a DC motor are structurally almost identical and their roles are reversible. However, their operational principles, energy conversion, and application differ significantly.
| Feature | DC Generator | DC Motor |
