Class 4 (4th Engineer) MET 📅 Jun 2024
(a) What is the function of insulation in an electric conductor? (3)
(b) What are the various classes of insulation? (8)
(c) What are the desired properties of insulating material? (5)
### (a) Function of Insulation in an Electric Conductor (3 Marks)
Insulation in an electric conductor serves several critical functions, primarily to ensure the safe and efficient operation of electrical systems. Its main roles are:
* **Electrical Isolation and Confinement:** The fundamental function of insulation is to electrically separate current-carrying conductors from each other and from the surrounding environment. This prevents unintended current paths, such as short circuits between phases or between a phase and earth (ground). It effectively confines the electric field to the region around the conductor, preventing its spread and interaction with other components or personnel.
* **Prevention of Current Leakage:** Insulation provides a high resistance path, thereby minimizing the leakage of current from the conductor. This ensures that the majority of the electrical energy is directed along the intended path, maximizing efficiency and preventing energy loss. Significant current leakage can lead to overheating, equipment damage, and electrical shocks.
