Class 4 (4th Engineer) MET 📅 Jan 2023
(a) what is the function of insulation in an electric conductor? (3)
(b) What are the various Classes of insulation? (8)
(c) what are the desired properties of insulating material? (5)
### (a) Function of insulation in an electric conductor (3 Marks)
Electrical insulation in a conductor serves several critical functions, ensuring the safe, efficient, and reliable operation of electrical systems, particularly in a demanding marine environment. Its primary roles are:
* **Electrical Isolation and Prevention of Current Leakage:** The most fundamental function is to confine the flow of electrons to the desired path (the conductor). Insulation provides a high resistance barrier, preventing the electrical current from escaping the conductor and flowing to unintended paths, such as the surrounding environment, other conductors, or the equipment casing. This ensures that the entire potential difference is maintained across the load, maximizing power delivery and minimizing energy losses.
* **Prevention of Short Circuits:** By electrically separating adjacent conductors or conductors from ground/earth, insulation effectively prevents short circuits. A short circuit occurs when a low-resistance path is created, leading to excessive current flow, which can cause overheating, damage to equipment, and fire hazards. In a marine context, this is vital for preventing system failures and ensuring vessel safety.
