Class 4 (4th Engineer) MEKG 📅 Sep 2024
(a) Why engineering materials are tested prior manufacturing of their components.
(b) Describe the various 'destructive' and 'non destructive' tests carried out on materials for shipboard used. Explain the purpose of each test and where same applied
### (a) Reasons for Testing Engineering Materials
Testing of engineering materials prior to the manufacturing of components is a fundamental requirement of quality assurance and is mandated by classification societies. It ensures that the materials possess the necessary properties to perform reliably and safely under the severe operating conditions encountered in a marine environment. The primary reasons are:
* **Quality Assurance & Specification Compliance**: To verify that the material supplied by the manufacturer meets the chemical composition and mechanical properties specified in the design and purchase order. This prevents the use of substandard materials which could lead to premature failure. For example, verifying the carbon content and tensile strength of steel for a pressure vessel plate.
* **Safety and Reliability**: The integrity of shipboard machinery and structures is paramount to the safety of the vessel, its crew, and the environment. Testing confirms a material's ability to withstand operational stresses, preventing catastrophic failures of critical components like crankshafts, connecting rods, boiler shells, or high-pressure steam pipes.
