Class 4 (4th Engineer) MEKM 📅 Nov 2024
(a) Why exhaust outlet of marine diesel engine turbocharger is lower than inlet temperature? (6)
(b) Why do we need an air cooler and why is the scavenge air temperature maintained at 40°C? (10)
### (a) Why exhaust outlet of marine diesel engine turbocharger is lower than inlet temperature?
The temperature of the exhaust gas at the outlet of a marine diesel engine turbocharger's turbine section is inherently lower than its inlet temperature due to fundamental thermodynamic principles and energy transformations:
* **Work Extraction for Compression:** The primary function of the turbine is to extract energy from the hot, high-pressure exhaust gases to drive the compressor, which supplies charged air to the engine. This extraction of useful work from the exhaust gases necessarily results in a reduction of the gas's internal energy and, consequently, its temperature.
* **Thermodynamic Process:** As the exhaust gas expands through the turbine's nozzles and rotor blades, its enthalpy ($$ h $$) decreases. According to the First Law of Thermodynamics, this decrease in enthalpy is converted into kinetic energy of the gas and then into rotational mechanical work imparted to the turbine shaft. Since enthalpy is a direct function of temperature for an ideal gas, a decrease in enthalpy signifies a drop in temperature.
