Class 4 (4th Engineer) MEKM 📅 May 2024
(a) Why exhaust outlet of marine diesel engine turbocharger is lower than inlet temperature? (6)
(b) Why do we need an air cooler and why is the scavenge air temperature maintained at 40°C? (10)
### (a) Why exhaust outlet of marine diesel engine turbocharger is lower than inlet temperature?
The exhaust gas temperature at the outlet of a marine diesel engine turbocharger's turbine side is invariably lower than its inlet temperature due to the fundamental principles of thermodynamics and energy conversion. This phenomenon can be explained as follows:
* **Turbine Operation**: The turbine section of a turbocharger is a heat engine. High-temperature, high-pressure exhaust gases from the engine cylinders are directed into the turbine housing.
* **Adiabatic Expansion**: As the exhaust gases enter the turbine, they expand rapidly through the nozzle ring and onto the turbine rotor blades. This expansion process is largely adiabatic, meaning there is minimal heat transfer to or from the surroundings.
