Class 4 (4th Engineer) MEKM 📅 Oct 2024
(a) Why tie-rods are provided on a 2-stroke main engine? (6)
(b) Why tie rods are placed close to the centerline of the crankshaft? (5)
(c) What is a tie rod pinch screw? And what is its purpose? (5)
### (a) Why tie-rods are provided on a 2-stroke main engine? (6 Marks)
Tie-rods are critical structural components in large 2-stroke marine diesel engines, designed to maintain the integrity and rigidity of the engine structure under immense dynamic loads. Their provision is essential for several reasons:
* **Counteracting Combustion Forces:** During the power stroke, the combustion of fuel generates extremely high pressures within the cylinder, exerting a substantial upward force on the cylinder cover. This force is transmitted through the cylinder liner and cylinder block. Tie-rods are pre-tensioned to counteract this upward thrust, effectively clamping the entire engine structure (cylinder cover, cylinder block/entablature, A-frames/columns, and bedplate) together in a compressive state. This pre-tensioning ensures that even under maximum firing pressures, the engine components remain under compression and do not separate.
* **Minimizing Tensile Stress in Cast Iron Components:** The main engine structure, particularly the bedplate, A-frames, and cylinder block, are typically constructed from cast iron. Cast iron possesses high compressive strength but is relatively weak in tension. By pre-tensioning the tie-rods, these cast iron components are kept under compression throughout the engine's operating cycle. This prevents them from experiencing significant tensile stresses, which could lead to cracking, distortion, or fatigue failure over time.
