Class 4 (4th Engineer) MEKM 📅 Nov 2022
(a) With a simple sketch, show the cylinder cover used on a low speed two stroke marine propulsion engine (10)
(b) Mention the mountings on cylinder cover and briefly explain the mountings used for fuel, air start and relief purposes. (6)
### (a) Cylinder Cover of a Low-Speed Two-Stroke Marine Engine
**1. Function and Purpose**
The cylinder cover, also known as the cylinder head, is a critical component of a large two-stroke diesel engine. It performs several essential functions:
* **Combustion Chamber Seal:** It forms the upper boundary of the combustion chamber, creating a gas-tight seal with the cylinder liner to contain the extremely high pressures (up to 200 bar) and temperatures (up to 2000°C) generated during combustion.
