(a) With reference to a three phase shipboard electrical distribution system:
Enumerate the advantages of an insulated neutral system; (4)
(b) Enumerate the disadvantages of an insulated neutral system; (4)
(c) State why an Earthed neutral system may be earthed through a resistor; (4)
(d) Compare the use of an insulated neutral system as opposed to the use of an Earthed neutral system with regard to the risk of electric shock from either system. (4)
### (a) Advantages of an Insulated Neutral System
An insulated neutral system, often referred to as an unearthed system or floating neutral system, maintains the neutral point isolated from the ship's hull (earth). This configuration offers several distinct advantages in a shipboard electrical distribution system:
* **Continuity of Supply on First Earth Fault:** The most significant advantage is that a single earth fault on one phase does not immediately complete a circuit through the ship's hull. Consequently, the system does not trip, allowing for continuous operation of essential services (e.g., steering gear, navigation equipment, emergency lighting, cargo pumps). This is crucial for maintaining safety and operational capability at sea.
* **Opportunity for Fault Location without Shutdown:** Since the system continues to operate with a single earth fault, personnel have time to identify and locate the fault using earth fault detection equipment (e.g., earth fault lamps or dedicated monitors) without interrupting power to critical loads. This facilitates planned maintenance and troubleshooting.
