Class 4 (4th Engineer) MEKG 📅 Jan 2025
(a) With the aid of a sketch describe the working of a shell and tube type fresh water generator. (10)
(b) What are the probable causes of fluctuating and unsteady vacuum in such an evaporator and what would be the consequence of such an unsteady vacuum? (6)
### (a) Shell and Tube Type Fresh Water Generator (FWG)
#### Principle of Operation
The shell and tube type fresh water generator, often referred to as a submerged tube evaporator, operates on the fundamental principle that the boiling point of a liquid is dependent on the pressure exerted upon it. By creating a high vacuum (approximately 92-95%) inside a sealed chamber (the evaporator shell), the boiling point of seawater is significantly lowered from 100°C at atmospheric pressure to around 40-50°C. This allows a low-grade heat source, typically the main engine's jacket cooling water (circulating at 70-90°C), to be used as the heating medium to evaporate the seawater without causing the formation of hard scale (e.g., calcium sulphate) which precipitates at higher temperatures.
#### Construction
