Class 4 (4th Engineer) MEKM 📅 Dec 2025
(a) (i) Describe with the aid of a sketch, a main engine exhaust valve which is hydraulically operated. (8)
(ii) Explain the operation of this valve. (4)
(c) State the materials used for the seat and valve described in (a) (4)
### (a) (i) Description of a Hydraulically Operated Main Engine Exhaust Valve
A hydraulically operated exhaust valve is a critical component in modern two-stroke crosshead marine diesel engines, designed for high reliability and precise timing. The entire assembly is housed in a valve cage, which is installed in the cylinder head cover. This allows for removal and overhaul without lifting the main cylinder head.
**Key Components:**
* **Valve Housing/Cage:** The main body which contains all components and is fitted into the cylinder head. It provides passages for cooling water to control the temperature of the valve seat area and prevent thermal stress.
