Class 4 (4th Engineer) MEKM 📅 Feb 2025
(a) (i) Describe with the aid of a sketch, a main engine exhaust valve which is hydraulically operated. (8)
(ii) Explain the operation of this valve. (4)
(b) State the materials used for the seat and valve described in (a) (4)
### (a) (i) Description of a Main Engine Hydraulically Operated Exhaust Valve
A hydraulically operated exhaust valve is a critical component in modern two-stroke marine diesel engines, designed for precise timing, robust operation, and effective sealing of the combustion chamber. Unlike cam-actuated valves, hydraulic systems offer flexibility in valve timing and lift profiles, enhancing engine performance and efficiency.
**Constructional Features:**
* **Valve Spindle (Stem and Head):**
