Class 4 (4th Engineer) MEKM 📅 Aug 2024
(a) (i) Describe with the aid of a sketch, a main engine exhaust valve which is hydraulically operated. (8)
(ii) Explain the operation of this valve. (4)
(b) State the materials used for the seat and valve described in (a) (4)
### (a) (i) Description of a Hydraulically Operated Main Engine Exhaust Valve
A main engine exhaust valve, particularly in large two-stroke diesel engines, is a critical component responsible for sealing the combustion space during compression and combustion, and for releasing exhaust gases at the end of the power stroke. Hydraulically operated valves offer precise control, high opening forces, and are essential for scavenging processes in uniflow scavenged engines. They eliminate the need for pushrods and rocker arms, providing a more compact and stiffer valve train.
#### **1. Concept and Construction**
A hydraulically operated exhaust valve is essentially a poppet valve where the opening and closing movements are actuated by high-pressure hydraulic oil, usually controlled by a dedicated cam-driven pump unit.
