Class 4 (4th Engineer) MEKM 📅 Apr 2024
(a) (i) Describe with the aid of a sketch, a main engine exhaust valve which is hydraulically operated (8)
(ii) Explain the operation of this valve (4)
(b) State the materials used for the seat and valve described in (a) (4)
### (a) (i) Description of a Main Engine Hydraulically Operated Exhaust Valve
A main engine hydraulically operated exhaust valve is a critical component in large two-stroke marine diesel engines, designed for precise timing, rapid opening, and controlled closing against high exhaust gas pressures and temperatures. Its operation relies on a dedicated high-pressure hydraulic oil system, synchronized with the engine's camshaft.
**Key Components and Construction:**
* **Valve Spindle (Valve Stem and Disc):**
