Class 4 (4th Engineer) MEKM 📅 Nov 2024
(a) (i) Describe with the aid of a sketch, a main engine exhaust valve which is hydraulically operated. (8)
(ii) Explain the operation of this valve. (4)
(b) State the materials used for the seat and valve described in (a) (4)
### (a) (i) Description of a Main Engine Hydraulically Operated Exhaust Valve
A hydraulically operated exhaust valve is a critical component in large two-stroke marine diesel engines, designed to precisely control the release of exhaust gases from the cylinder, facilitate effective scavenging, and ensure proper combustion cycle timing. Its operation is independent of the engine camshaft for direct mechanical linkage, offering flexibility in timing and lift characteristics.
**Concept and Function:**
* **Purpose:** To open and close the exhaust port in the cylinder head, allowing spent combustion gases to exit the cylinder and enabling fresh scavenging air to enter.
