Class 4 (4th Engineer) MET 📅 Oct 2024
Overcurrent protection relays are built into main alternator breakers to safeguard the individual alternators and the distribution system against certain faults.
(a) Sketch a typical relay. (8)
(b) Describe the operation of the relay sketched in (a) (8)
The overcurrent protection relay is a critical safety device employed in marine electrical power systems to safeguard individual alternators and the entire distribution network from damaging overcurrent conditions, such as overloads and short circuits. It acts as the 'brain' of the protection system, sensing abnormal current flows and initiating the isolation of the faulted section.
### (a) Sketch of a Typical Electromechanical Induction Disc Overcurrent Relay
A typical electromechanical overcurrent relay, often an Inverse Definite Minimum Time (IDMT) type, is a robust and proven device. A sketch of such a relay should illustrate its main components and their interrelationship. While I cannot generate an image, the diagram should visually represent the following key components:
* **Electromagnet System:** This consists of a laminated iron core with a primary winding (operating coil) through which the fault current (derived from the CT secondary) flows. The core typically has two poles, often with a 'shaded pole' arrangement on one to create a rotating magnetic field.
