Class 4 (4th Engineer) MET 📅 Jun 2025
Overcurrent protection relays are built into main alternator breakers to safeguard the individual alternators and the distribution system against certain faults.
(a) Sketch a typical relay. (8)
(b) Describe the operation of the relay sketched in (a). (8)
### (a) Sketch of an Attracted Armature Instantaneous Overcurrent Relay
A diagram of an attracted armature type instantaneous overcurrent relay is required. The sketch should clearly label the following essential components:
* **Current Transformer (CT):** Showing the primary connected to the main power line (from the alternator) and the secondary connected to the relay's operating coil.
* **Operating Coil (Relay Coil):** An electromagnet that is energized by the secondary current from the CT.
