Class 4 (4th Engineer) MEKM 📅 Jul 2022
Show the safeties incorporated in starting the slow-speed engine aided by a sketch and brief explanation of safety elements. (16)
### Introduction
The starting air system of a slow-speed marine diesel engine operates at high pressure, typically 30 bar. This stored pneumatic energy poses significant risks if not controlled correctly. A catastrophic failure, such as a starting air line explosion, can cause severe damage to the engine, surrounding machinery, and endanger personnel. Therefore, a multi-layered system of mechanical safeties and operational interlocks is incorporated to ensure the engine starts safely, reliably, and only when all pre-conditions are met.
### System Safeties and Interlocks
The safety elements can be broadly categorized into Mechanical Safety Devices, which provide physical protection against overpressure and explosions, and Operational Interlocks, which are logic-based checks integrated into the engine control system to prevent starting under unsafe conditions.
